I've been having major issues with my 69' Spider.
Last summer I drove to Le Mans classic in my Fiat, the first lengthy journey she had
been taken on since a full rebuild over 3 years ago. Plenty of mileage had been covered
prior to this journey without any issues.
The car would start jumping and jerking and then stall after 30 miles or so after crossing into France.
The engine then wouldn't start. At first I thought it was fuel evaporation due to the hot weather and
running temps. or bad fuel.
After letting the engine cool it would fire up and would be OK for the remaining journey.
The following day it would be constantly jumping / stalling.
I checked the Fuel filter to make sure it wasn't clogged but replaced. Blew air through the fuel line to
check for blockages. Checked all spark plugs, disi cap and points etc.
On returning to the UK, I removed and checked the fuel tank to see if there was any debris, it was clear.
Checked the mechanical fuel pump and diaphragm which seemed OK but replaced it all the same.
After all these checks had been made, I drove the car but it still continued to kangaroo and stall.
My afterthoughts are that it could be my Carb which is the original Weber 26/34 DHSA.
Very frustrated
Your assistance and help, as ever, is always fantastic.
Cheers,
Charles
