hi everyone
If you just registered, post a brief greeting in here.
metallica3426
hi everyone
Post by metallica3426 »
New to the forum have a 73 124 spider and thought id join seeing as it needs a little work although its been in my family since it was bought brand new in 73 by my father, it has 62,000 on the clock, i'm sure down the road ill have questions.
Thanks!
Ryan
mdrburchette
Re: hi everyone
Post by mdrburchette »
Welcome to the Early Bumper Club, Ryan! Where are you located? Do you have pics of your car?
metallica3426
Re: hi everyone
thank you, no pics of the car yet its been in the garage for the past 10 or so years with a no start issue, just started looking into it. believe its the points switch over relay so im going to run it on a mod i found on International Auto Parts to run it one set of points, then need to do the brakes after that well have some pictures up, located out of Massachusetts.
donm
Your car is a: 1980 spider [carb]
Re: hi everyone
Post by donm »
Great to see someone else here from snow covered MA. Where are you located?
Don
1979 Spider
2001Saab SW
2004 Saab Aero
2ndwind
Your car is a: 1982 Spider
Re: hi everyone
Post by 2ndwind »
Ryan,
Welcome. It is typically suggested that you change a lot of the rubber parts after 10 yrs of sitting, particularly the timing belt.
Steve
1982 Red Spider 2000
1919 Old Town Sailing Canoe
metallica3426
Re: hi everyone
Don, out of North Reading 20 miles north of boston and belts are on the to do list along with fluid
donm
Re: hi everyone
Post by donm »
Not too far from me, just down 128 a few miles. My car is put away for the winter but in the spring when the snow and salt are gone, I'd like to come see it. I used to have a '70.
1979 Spider
2001Saab SW
2004 Saab Aero
TulsaSpider
Re: hi everyone
Post by TulsaSpider »
Welcome!Does the motor turn freely? If so you are in good shape! You can convert the points into electronic, or just get an electronic dizzy from a later car.
metallica3426
Re: hi everyone
it does spin freely i actually got it running the past few days, the points change over relay was bad i converted it to 1 set of points and it fired on the key hit runs well just need to time it do the brakes and get some tires and finish the tune up and it will be coming out of the garage in the spring, and yea once shes road worthy sure you can come see
