Rear Brakes
Kent124
Rear Brakes
Post by Kent124 »
Since Whoa Brakes and EBC Green pads come only for the front, what is everyone using in the rear?
Looking at overhauling or replacing calipers all the way around and replacing rotors and pads for standard 13" rims.
mdrburchette
Re: Rear Brakes
Post by mdrburchette »
You don't really need much brake on the rear. My stock ones work just fine with the front Whoa brake setup. Some racers use the Feroda racing pads for the front of an RX7 and sand them down to fit.
surfingfreeman
Your car is a: 1982 2000 FI
Re: Rear Brakes
Post by surfingfreeman »
EBC greenstuff for rear are available here is the contact info the part #DP-2130 I believe contact info is 305-253-3334 and talk to Luis. They are a full Warehouse Distributor with access to our warehouse in Southern California. I should be getting mine delivered any day now and will update.
Mike
Re: Rear Brakes
EBC told me they do not make Green Stuff for the rear. I carry Green Stuff for the front, and EBC made up Yellow Stuff for the front and rear for me. They warn against mixing the colors; if you use Yellow Stuff up front you should use it in the rear also. They suggested standard pads in the rear with Green Stuff up front
maytag
Re: Rear Brakes
Post by maytag »
So Cal Mark wrote:EBC told me they do not make Green Stuff for the rear. I carry Green Stuff for the front, and EBC made up Yellow Stuff for the front and rear for me. They warn against mixing the colors; if you use Yellow Stuff up front you should use it in the rear also. They suggested standard pads in the rear with Green Stuff up front
I've got to think that using a different clor in the rear is no wose (and maybe significantly better) than usng OEM on the rear. !!!
I've got to think that their warning against mixing colors is about differences in heat-up, initial bite, etc. I mean, lets' remember that in this litigious society, people are ONLY going to specifically recommend doing something that they have a) specifically tested, and b) put their liability exposure in order. The will warn against ANYTHING ELSE.
131
Re: Rear Brakes
Post by 131 »
I've got Greenstuff pads on the rear of my 131. It's got a 132 disc rearend in it, which uses the same size discs and calipers as the 124. The pads were originally in the front of my car, they'd only done about 1000 miles when I put larger brakes on the front. I welded a tab on the back to fit the slot in the piston and filed the friction material down for the narrower caliper. Works a treat!
Mick.
surfingfreeman
Re: Rear Brakes
I spoke with 2 different EBC reps and the pads are in the mail we shall see. Attached is a correspondence
On Fri, Oct 15, 2010 at 11:04 AM, Chris Noah <chris@ebcbrakesusa.com> wrote:
Hello Michael,
So we do make your rear pads and rotors as well!
I don’t have any stock of your rear pads here in the USA but I can request them from the UK if you would like?
Regards,
Chris Noah
surfingfreeman
Re: Rear Brakes
From: michael freeman [mailto:surfingfreeman@gmail.com]
Sent: Friday, October 15, 2010 12:51 PM
To: chris@ebcbrakesusa.com
Subject: Re: Contact Us
Hi Chris
Just to double-check, i am told that the rears of the Fiat Spider 2000 require a thinner pad than the fronts so this part is thinner and will fit correct?
Hi Michael,
Yes… your fronts measure 17.5mm and your rears at 10mm.
 Regards,
Chris Noah
Re: Rear Brakes
I've dealt with Chris and also directly with EBC in the UK. As recently as the SEMA show in Nov they both told me the Green Stuff was not available for the rear. It must be a really recent decision to offer it if indeed they have it in stock
124ADDHE
Your car is a: 1974 Spider Amalgamation with C40 Solex
Re: Rear Brakes
Post by 124ADDHE »
When I installed the yellowstuff pads from Allison, the things would not fit with the anti-squeal shims, maybe in another 8,000kms (I just tried again and they still wont fit!). The brakes obviously wear well and are excellent after broken-in (I have no booster so i can really tell by fell that their friction is much better than the ferodo's that i had on prior).
2 thumbs up!
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
