1 wheel spins the drive shaft the other one does not
majicwrench
Re: 1 wheel spins the drive shaft the other one does not
Post by majicwrench »
At this point you do not need to remove pumpkin. You are right, axle should not move in-out 1" . Pull caliper, pull rotor, pull axle in and out to see what is not right. Pull snap ring, axle comes out, repair whatever is amiss and put er back together.
81SPIDERMATT
Post by 81SPIDERMATT »
well amongst the football...the car is up on jacks and the first thing i think could be a problem is the long trailing arm is snapped in half... as it was going could it mimickk a problem.. like loose wheel bearing....also what now.. just replace the arm... should i do all three..( there are three right??) do i go into the axle?? not that it is up on stands under the car and not the rear end the side to side play i thought was coming frome the wheel does not appear to be there...
81SPIDERMATT
panhard rod... keeps the axle from moving side to side... that is what has snapped......
majicwrench
Obviously, fix what is broken!
81SPIDERMATT
done..part is ordered....thanks
azruss
Post by azruss »
there is an early and late style panhard rod. make sure you order the right one. never seen one break that wasnt in a wreck.
81SPIDERMATT
item 33532... at IAP.... fingers crossed
81SPIDERMATT
at one point i think the car was in an accident... po made mention of having a parts car and combining the two to make one
v6spider
Your car is a: 4.3L V6 Powered 1972 124 FIAT Spider
Post by v6spider »
Delete post
http://www.v6spider.com
v6spider
Post by v6spider »
Glad you figured it out...btw the trailing arms are weak as they are. Doesn't mean it was in a wreck. Someone may have hit a curb or it may have been rusty. I have broke two myself before I made my own. Check the car for filler. A paint thickness gauge will tell you....just my two bits....:)
Anyway a new arm is definately an easy fix.
Rob
