Spider Fuel Lines
Aren't those flares more like a flange? The fuel injection tube flanges are a bit extreme for rubber hose connections making it kind of hard to get the hose on. Is it possible to use these tools to form it part of the way to create the bulge instead of the full flange. How much do these tools cost and where are they available?
i've read on several forums that you can do the first step on a double flare and then that will create a suitable ridge. Just cause I've read it doesn't mean it's the best way to do this though!
this has to be what we are talking about right: Bubble flaring tool
or maybe the Hydra-flare tool??? check this last link for a bunch of tools to see what else there is....
those hydraflare tools are fairly new to the market, so that means high prices for awhile. Try Harbor Freight. Or, why not buy steel brake line, it comes with a double flare end and fitting. Then buy hose nipples to screw on to the line? If you need more length, just put multiple lines together with unions
or I could buy the line and some fittings and make it the right length with no unions and buy some nipples to hook the hose to. then I could buy the double flare tool, which I'm sure I'd use plenty.So Cal Mark wrote:those hydraflare tools are fairly new to the market, so that means high prices for awhile. Try Harbor Freight. Or, why not buy steel brake line, it comes with a double flare end and fitting. Then buy hose nipples to screw on to the line? If you need more length, just put multiple lines together with unions
shopping list:
Double flaring tool
5/16 line
barbed fitting (help me get the right size here if you know...)
what kind of fittings do i need to end off my line to screw on the barbed hose fittings?
Double flaring tool
5/16 line
Classic Tube makes fuel lines for all sorts of cars and can custom make what you may need. It may be cheaper than buying the tools to do it yourself. Just a thought.
http://www.classictube.com
1 step ahead of you Bob, just bid on 25ft of each 1/4" and 5/16" steel lines. also found a huge set of fuel and vacuum hoses at a good price too. I'll just make a complete overhaul on all my hoses....Bob wrote:These tubes sizes are very close to 5/16 and 1/4 which are easier to find and, my guess, a lot less expensive than metric tubing. If you are replacing the steel tubes, you will most likely be replacing the rubber hoses, too? Same goes with the rubber. English sizes are readily available.
