I've got three questions regarding brake pads:
What kind would be best for spirited driving? The originals seem to fade pretty quickly.
Should I be concerned with the front and back or just the front brakes?
Is it hard to replace them...something a nonmechanical female can do in two weeks if she is diligent?
Brake pads
Sounds like you're sorted, but I thought I'd make a mention of "Silverline" pads. UTTER EFFing CRAP !
Don't touch them. I put a set on my Mitsi. first time they got used on any hard work, I virtually ran out of brakes, faded terribly AND DID NOT RECOVER even when allowed to cool off
Yes they went back and I demanded my money back.
Another very good pad is the HAWK Brake HPS Compound. This is a good pad for street and track lapping days. This is actually a rear pad for the Mazda RX-7. This is a low dust, and rotor friendly pad. The stock number is #HB158F.515, and is available from Tire Rack.
For racing use, use the same pad in the HAWK Blue compound. That is the pad I race with (no option for aftermarket brakes in SCCA), and it transforms the brakes on a FIAT. No fade. The minus is that they are high dust, and rotor aggressive. But, given you can buy the rotors for as littel as $15 each, who cares, as long as you can stop.
I would stay away from the EBCs in any color. Compared to the HAWK, they're just not a very good pad - very aggressive to the rotors, and prone to glazing, and de-lamination.
Thanks for the info, Bill. I heard the Hawk pad was impressive, but didn't know about the EBC.
Mark, you were wrong! I'm stuck trying to get that little angled blocking plate between the caliper and spring...and I even tried it with my eyes closed. I have the bottom one in with the cotter pins in place, but the top one will not go in. Is there a trick to this?
use a flat bladed screwdriver in-between the caliper and the bracket to pry the caliper down against the spring, then you can start the wedge in. It can be tapped into place easily. Remember, those slides should be very clean and caliper grease should be applied in that area. Those pieces need to move easily when the brakes are applied
