Spider Progress Update
CarlosJavier
Post by CarlosJavier »
Hey everyone, just sharing some pictures of the Fiat's current state... This site has been a wonderful help.
2ndwind
Your car is a: 1982 Spider
Re: Spider Progress Update
Post by 2ndwind »
Looking good. What turn signal lights did you choose for your front?
Steve
1982 Red Spider 2000
1919 Old Town Sailing Canoe
Chap
Post by Chap »
Very nice! Are those "OG Oldskool" wheels? If they are, do you have any issues with the tires rubbing?
SLOSpider
Post by SLOSpider »
Looks good. i was thinking about a set of wheels like those. Are they on adapters?
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
Fiat88
Post by Fiat88 »
Nice spider! Love the wheels.
CarlosJavier
Thanks guys...
I got the car as a stock non-runner in June; it had been sitting for seven years. Here's a list of what I've done:
-new battery
-replaced dead starter
-cleaned fuel tank
-replaced dead fuel pump
-new fuel filter
-replaced all rubber fuel lines
-installed reconditioned injectors
-repaired mass air flow sensor
-replaced distributor pick-up
-new master cylinder
-replaced all brake hoses
-installed remanufactured calipers
-new brake pads
-removed bumpers and relocated OEM turn signals
-cut 1.5 coils from all springs
-custom made air dam
-sewed in a new rear window
-new lug bolts
-4x98 to 4x100 wheel adapters (31 mm thick)
-Drag DR-20 wheels 15x7, +40 offset (actual offset with spacers is +9)
-195-55-15 tires
-clean, clean, and clean some more
Surprisingly, the oil, coolant, and air filter are still in good state. Next up is an alignment...
The following still need attention:
-fuel tank level sending unit
-window motors are weak
-wiper motor is weak
-radio wiring needs repair
-hazards switch got stuck in the on position (disconnected for now, so no turn signals either)
-paint and body
CarlosJavier
2ndwind wrote:Looking good. What turn signal lights did you choose for your front?
Those are the OEM turn signals. I bent open the brackets that held the bumper shocks and popped the turn signals in there.
Chap wrote:Very nice! Are those "OG Oldskool" wheels? If they are, do you have any issues with the tires rubbing?
The wheels are Drag DR-20s; the poor man's "Oldskools". There is slight tire rub on the plastic liners' rear when the steering wheel is turned almost all the way.
SLOSpider wrote:Looks good. i was thinking about a set of wheels like those. Are they on adapters?
Yes sir.
