Vapor Seperator Gasket?
I removed my oil vapor seperator and cleaned it out as I'm replacing all the breather hoses. The old gasket was dried out and brittle and I kind of broke it into several pieces forgetting I could of used it as a template.
I bought a roll of cork gasket paper, will that material be fine to make a new gasket or should I use something else? Thanks.
- TulsaSpider
Re: Vapor Seperator Gasket?
That should work just fine. I would use some gasket sealant as well
Would you use RTV gasket maker or this Hi-Tack Sealer to seal the gasket? Thx.
