light blue '84 pininfarina Azzurra: the paint has been out in the weather for too long. This is a car I am looking at, but do not yet own. I think a good work-over with rubbing compound can bring back a good amount of the original paint, but the trunk and hood have light surface rust, a bit of one body panel has some bubbling/flaking, and there is light rust along the rear edge of the doors (right along the rear vertical seam). The interior blue paint not exposed to the weather is great.
Short of stripping the car and having a total re-paint, could anyone suggest some ideas for getting the car into stabilized shape until I can swing a paint job (and until I am sure that, mechanically, this car is a keeper)?
Are the original paint codes for the light blue Azzurra Spiders still available?
Is that blue shade a difficult or complicated color and finish to work with/replicate?
"Azzurra" Blue (code #473)" is all I have found so far on this color, and I am assuming there was only one shade of "Azzurra light blue" in '84.....?
touch-up paint recommendations
- DUCeditor
- Your car is a: 1977 FIAT 124 Sport Spider
- Contact:
Re: touch-up paint recommendations
If the entire car is in poor shape, or if the color is a metallic one, there is little you can do to get a good match other than find the correct paint and have it properly applied.
But if it is a matter of touch up or, as in the case of my Spider, the problem is localized to the lower front cowl where the original paint is chipped or peeling do to the fact that it was applied over the plastic, textured, anti-rust, coating, there is an answer (and it may surprise you). Simply take a decent sized peeling piece of the paint to your local hardware/paint shop and have them color analyze it and mix a can.
I did this on my Spider and the results are more than acceptable. Since that part of the car is textured anyway (and in the case of my 32 year old car also 'textured' by repeated stone hits), I simply applied two coats with a foam brush. Close examination mighty reveal what I've done, but it does not stand out at all to even an admiring viewer.
I used the same paint to 'fix' the chips in the door edges, etc.
Obviously this is for a runner (but even a nice runner!), not a 'show car.'
-don
-don
agreed with the above. if your paint is in bad shape, the touch up paint will be new and won't match at all (tried this personally). i have ordered paint from http://www.touchuppaintonline.com to repaint the whole car for under $150 and it turned out great. just couldn't get over paying someone $2500 to do it...
Love to see pix! And by the way, the light blue 473 paint code is not showing up as an option on touchuppaintonline.com.maxedout wrote:agreed with the above. if your paint is in bad shape, the touch up paint will be new and won't match at all (tried this personally). i have ordered paint from http://www.touchuppaintonline.com to repaint the whole car for under $150 and it turned out great. just couldn't get over paying someone $2500 to do it...
edit: looking again at the car in question, the paint code sticler is still on the underside of the trunk lid, and it reads, "876 azzurro met."
I've been looking for some time for the correct color, I have yet to find it. The conclusion I have reached is that short of having it analyzed and matched in a good shop I think I'd rather find a close match in a stock modern car color so that it will be easier to match later in the event that (lets all whisper it...) someone else inflicts damage on my car. I'll let you know what I settle on, I just know that the red has to go.
From the car paint on-line website http://www.carpaintonline.com/paints-by ... ModelId=87
The Pininfarrina search comes up with what appear to be Ferrari paint codes:
A search for 1984 Fiat provides more information which may be correct for our cars:
12970 461 yuniper fiat 1964 - 1989
13315 489 azzurro met 2ct fiat 1966 - 1993
15298 105 blu lord fiat 1978 - 2001
15298 438 blu lord fiat 1978 - 2001
19027 007 blu saviem fiat 1984 - 1995
19031 481 azzurro fiat 1981 - 1985
190332 471 blu petrol met fiat 1984 - 1996
19418 478 azul sky fiat 1984 - 1987
19569 044 blu caraibi fiat 1984 - 1988
22656 583 beige visone fiat 1965 - 1987, 1984 - 1987
27963 569 avorio scuro fiat 1982 - 1985
27971 504 beige scuro fiat 1974 - 1984
32871 604 grigio garda fiat 1970 - 1996
33196 620 alluminio met fiat 1968 - 1997
35883 383 verde night fiat 1982 - 1987
35887 610 grigio mirage fiat 1978 - 1993
35888 697 bianco perla fiat 1984
36075 484 azzurro chiaro fiat 1982 - 1987
43920 388 verde amazzonia fiat 1968 - 1985
47581 567 kaki oliva fiat 1984
52104 173 bordeaux fiat 1984 - 1985
60824 299 giallo sole fiat 1974 - 1985
61687 026 orange europcar fiat 1984
72024 171 ralley red fiat 1972 - 1984
72338 136 cherry red fiat 1978 - 1984
74259 886 rosso chiaro fiat 1984
74260 160 rosso siam fiat 1980 - 1988
74260 854 rosso siam fiat 1980 - 1988
74261 111 rosso garanza fiat 1982 - 1987
74263 104 rosso vermelho fiat 1981 - 1986
74265 137 rosso scuro fiat 1982 - 1988
74266 181 rosso fiat 1983 - 1986
74267 102 rosso scuro fiat 1984 - 1992
74268 112 rosso racing fiat 1981 - 1987
74382 167 rosso fiat 1950 - 1991
74449 152 rosso vivo fiat 1968 - 1985
74578 155 rosso monza fiat 1962 - 1991
82048 273 yellow fiat 1971 - 1984
82255 106PIN avorio safari fiat 1978 - 1984
82255 285 avorio safari fiat 1975 - 1984
83716 266 avorio fiat 1984
83727 262 giallo fiat 1984
91275 224 bianco corfu fiat 1978 - 2001
FIA*0079 *0079 fiat blu norma fiat 1970 - 1995
FIA*0080 *0080 fiat giallo fiat 1970 - 1995
FIA026 026 orange europcar fiat 1984
FIA031 031 arancio fiat 1979 - 1988
FIA044 044 blu caraibi fiat 1984 - 1988
FIA0462 0462 blu fiordo fiat 1981 - 1990
FIA0462 IC014 blu fiordo fiat 1981 - 1990
FIA0684 0684 bianco vela fiat 1981 - 1984
FIA079 079 blu fiat 1965 - 1997
FIA152 152 rosso vivo fiat 1968 - 1985
FIA152219 152219 blu ancorasc fiat 1970 - 1997
FIA157 157 rosso amaranto fiat 1962 - 1989
FIA161:84 161 rosso met 2ct fiat 1984
FIA171 171 rosso arancio fiat 1972 - 1984
FIA183 183 rosso met 2ct fiat 1984 - 1993
FIA203 203 acquamarina fiat 1983 - 1985
FIA206:70 206 jaune service fiat 1970 - 1988
FIA207:68 207 white fiat 1968 - 1988
FIA222 222 bianco beta fiat 1978 - 1984
FIA224 224 bianco corfu fiat 1978 - 2001
FIA252 252 avorio fiat 1982 - 1995
FIA273 273 giallo cromo fiat 1971 - 1984
FIA277 277 jaune ptt fiat 1965 - 1989
FIA302 302 vert bussing onf fiat 1974 - 1989
FIA331 331 verde salvia fiat 1979 - 1984
FIA33122 33122 bleu fiat 1960 - 1997
FIA373 373F verde acquario fiat 1983 - 1984, 1984
FIA373 ESN verde acquario fiat 1983 - 1984
FIA373F 373F verde acquario fiat 1983 - 1984, 1984
FIA382 382 verde scuro met fiat 1984 - 1991
FIA409 409 blu agadir fiat 1984 - 1989
FIA422:84 422 blu fiat 1984 - 1985
FIA452 452 blu met fiat 1982 - 1988
FIA457 457 giada met 2ct fiat 1984 - 1991
FIA469:72 469 bleu fiat 1972 - 1989
FIA474003 474003 fiat pesco norma fiat 1970 - 1995
FIA474231 474231 norma fiat fiat 1970 - 1995
FIA474232 474232 giallo norma fiat 1970 - 1995
FIA474353 474353 fiat verde norma fiat 1970 - 1995
FIA474834 474834 blu scuro norma fiat 1970 - 1995
FIA474835 474835 blu norma fiat fiat 1970 - 1995
FIA482 482 azzurro chiaro fiat 1982 - 1987
FIA483:84 483 turchese festival fiat 1984
FIA501:84 501 platino met 2ct fiat 1984 - 1987
FIA543 543 verde polizia fiat 1983 - 1984
FIA567 567 kaki oliva fiat 1984
FIA579 579 camoscio fiat 1977 - 1984
FIA583 583 beige visone fiat 1965 - 1987, 1984 - 1987
FIA602:84 602 nero met fiat 1984 - 1995
FIA602:84 Y nero met fiat 1984 - 1992
FIA603 603 nero met fiat 1984
FIA607 607 grigio peltro fiat 1984 - 1987
FIA639 639 grigio quartz met fiat 1984 - 1987
FIA654 654 grigio finanza fiat 1962 - 1998
FIA679 679 grigio scuro met fiat 1983 - 1988
FIA683 683 grigio fiat 1983 - 1989
FIA737 737 marrone met fiat 1984 - 1985
FIA802 802 rosso amarillis fiat 1984
FIA806 806 tabacco met 2ct fiat 1984
FIA807 807 grigio fumo fiat 1984
FIA809 809 grigio chiaro met fiat 1984
FIA812 812 giada fiat 1984
FIA818 818 verde fiat 1984
FIA825 825 azzurro fiat 1984
FIA827 120 blu medio fiat 1979 - 1984
FIA827 827 blu medio fiat 1979 - 1984
FIA840 840 oro met 2ct fiat 1984
FIA849 188 marrone met fiat 1983 - 1985
FIA849 849 marrone met fiat 1983 - 1985
FIA854 160 rosso siam fiat 1980 - 1988
FIA854 854 rosso siam fiat 1980 - 1988
FIA864 864 giallo hertz fiat 1982 - 1990
FIA866 866 colorado brown fiat 1984
FIA872 872 polar ice blue fiat 1984
FIA876 876 azzurro met fiat 1984
FIA900 224651 grigio scuro fiat 1983 - 1984
FIA900 2873003 grigio scuro fiat 1983 - 1984
FIA900 900 grigio scuro fiat 1983 - 1984
FIA956 956 grigio opaco fiat 1984 - 1994
