A local group of classic car enthusiasts decided that a drive up to our local ski resort for Sunday luch would be a great way to enjoy the sunny spring weather. Unfortunately for us, the ski season had been extended due to the excellent snow conditions still being experienced, so that meant all vehicles heading to the resort had to carry snow chains in case of adverse road conditions.
Needless to say, we carried on up until reaching the point in the photograph where a $3000 fine can be imposed on drivers who continue on and are found not to be carrying chains.
Has anybody on the forum ever fitted chains to their Spider's wheels for driving in the snow?
Foiled by chains
- Curly
Foiled by chains
Curly from Oz
Re: Foiled by chains
Never had the reason for chains on my Spider, but I did have snow studs on my 280Z.
- Redline
- Your car is a: formerly a 1971 Fiat 124 BC Coupe
You won't fit them on those wheels, especially if the car has been lowered. They aren't mounted in this image (maybe they should be ), but my friend could only use chains with narrow wheels & tyres and standard ride height. They will also eat up alloy wheels.
http://www.124bc.com
OMG! Your friend is crazy!
Those are great pictures! You guys know how to have a good time! It doesn't look like anyone cared about the little heater in the car anymore?
When I bought my 72 Coupe it had a set of chains in the trunk, never tried to use them though.
Hal
Hal
- Redline
When you get several metres of snow each winter, you stop worrying about whether or not your car is "ok for winter". You just learn to drive around it. Although even I had to eventually admit that an 800kg, mid-engined sportscar with a flat undertray and zero ground clearance made a better sled than car...
I used my 70 as a daily driver in Vancouver BC in the mid/late 70's. I did put "snow tires" on,but they were virtually useless as there was no real weight over the rear axle. Three inch steel plates helped a bit but the tire technology then I thought was not what it was today. I ended up buying a set of those cable chains and they did work better and were safer as the west coast snow is very wet and after a bit of traffic is like driving on ice. After the fiat was sold, I bought a VW and mounted studded tires in the winter,never had a problem since with studded tires.
I owned two 124's in the years I lived in Denver and not one time "needed" chains. And not one time got stuck or stayed home for lack of them. The Fiat laughs at snow. LOL
