Good fuel pressure
Good fuel pressure
I just change the fuel pump in my car and when the vaccum hose is disconnected from the regulator, i can read 38PSI. If i plug the hose back, i can read 28PSI. I cleaned the 4 injectors in ultrasonics machine for 1 hour using acetone and no heat. But vibration eat the acetone so do it outside. One of the injectors is missing parts on the side of the plastic head . I replace all seals and put them back. I just unplug the hose and plug it whit a srewdriver bit to run at 38PSI. Anyone see any problems?
- engineerted
- Your car is a: 1974 124 spider
Re: Good fuel pressure
YES! Acetone? That stuff will eat any type of plastic. A better choice would be denatured alcohol or kerosene.
Ted
Ted
Ted
So the solution is new or rebuilt injectors?????
