best source for brake parts, and cleaning up rusty pistons
o0sara0o
Post by o0sara0o »
What's the best source (i.e. price/quality) for brake parts? Right now looking at new front rotors and maybe even calipers for 1980 2000.
Also, has anyone had luck with cleaning up the rusty pitting found on slave pistons, rather than simply buying the whole new caliper? JB Weld?
Thanks for the advice.
Andy (and Sara) in Bluffton, OH
mdrburchette
Re: best source for brake parts, and cleaning up rusty pistons
Post by mdrburchette »
I try to use our faithful Fiat vendors when I can for parts. Pads and rotors are very inexpensive through International Auto Parts or Vick Auto. Also check Midwest Bayless for availability. As for calipers, you can get rebuilt ones cheaper at the chain stores.
if the caliper pistons are pitted, they need to be replaced.
robmorais
Post by robmorais »
Advance Auto Parts has re-built calip BUT you have to check them out carefully. I had to order 4 or 5 before I got 2 that were done right... check all the screws and the hose connections.
Rob
