engine vaccum
engine vaccum
If i run the engine idle and plug a vaccum gauge, what i'm supposed to read??????
Re: engine vaccum
if you connect the gauge to a port above the throttle, it will read 0 at idle. If you attach at a port below the throttle, it should read from 14 to 20 inches depending on various factors
Re: engine vaccum
So it's normal to have 0 at the advance timing hose.
- Your car is a: 1975 Spider
Re: engine vaccum
at idle , yes once you open the throttle the vacuum should rise
son has 78 spider
son has 78 spider
