Tube Bumper Modify Question? Removing one front tube bar...
Fiat88
Post by Fiat88 »
I'm planning on removing the bottom tube from the front bumper and just using the top tube,then painting it black. I've seen one member do it and it looks nice + less weight. My question is how do you cut off the welds? Never did this before and most likely gonna have to bring it down to a shop, what would they use blow torch or grinding wheel? And do you think I could still use the same mounting brackets on the bumper or is it best have have some kind of new mounts welded on. Thx.
azygoustoyou
Re: Tube Bumper Modify Question? Removing one front tube bar...
Post by azygoustoyou »
Since your painting it. A torch would work. It would be a lot faster than the cut off wheel. They use the same mounts.
SLOSpider
Post by SLOSpider »
Plasma Cutter is the bee's knee's
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
BEEK
Your car is a: 1975 Spider
Post by BEEK »
comeon down to florida, i have a plasma cutter, and a welder :wink:
75 spider
son has 78 spider
htchevyii
Post by htchevyii »
Buy a angle grinder and a cut off wheel, not as quick as the plasma cutter, but does a fine job.
Trey
Fiat88
Post by Fiat88 »
BEEK wrote:comeon down to florida, i have a plasma cutter, and a welder :wink:
I'm on my way! :mrgreen:
I'm just gonna bring it down to the local garages by City Field via the VW Golf. Will take some pics of the outcome.
backyardbill
Post by backyardbill »
Anyone have a picture of the "one" tube bumper?
Fiat88
Post by Fiat88 »
Here's racedaves car.
backyardbill
Thanks. Not bad. It would be nice to see a whole bunch of Spiders lined up with different bumpers to see which looks the best. Also, any photos or how he did the rear bumper?
Fiat88
Post by Fiat88 »
backyardbill wrote:Thanks. Not bad. It would be nice to see a whole bunch of Spiders lined up with different bumpers to see which looks the best. Also, any photos or how he did the rear bumper?
I don't think he did anything with the rear but I'm not 100% sure.
Fiat88
Post by Fiat88 »
Haven't cut the front bars yet but will be doing so soon. One shop said $75 so I guess I have to pay around that but right now I have a painting question. I primed and painted the rear bumpers black using a duplicolor black spray can but I'm wondering do you guys think I should clear-coat them too? Thx.
SLOSpider
Post by SLOSpider »
If you do you may should stick with the same type and brand of paint. It may help it keep its shine longer.
1975 124 Spider
MyWE4
Post by MyWE4 »
I was in a rush Sat. and posted in the other bumper thread.... :oops:
anyway, here is what I did with the front...
I think with it painted satin black and pulled tight to the body it could work!??
as far as cutting , I used my 3in air zip wheel....it was a piece of cake...if you have a small high speed grinder with a cut off wheel it can be done in 20 min.(take $75 and buy a tool :wink: )
Fiat88
Post by Fiat88 »
I would buy a cut-off wheel and do it myself but I live in a co-op with seperate multiple attached garages. I'm guessing it would make a lot of sparking! :lol: So, its not the ideal or safest working environment for that kind of work.
MyWE4
Post by MyWE4 »
did a little work to the bumper, ground off the rust, drilled the mounting shocks and gave it a test fit.....
