Supercharger
Supercharger
Did anybody install one on a fiat spider?????
- Your car is a: 1985.5 Volumex
Re: Supercharger
Yup....and it was Pininfarina themeselves who install an Abarth supercharger on an Abarth engine and called it a Volumex.
Here's mine...
Cheers,
Jim
Here's mine...
Cheers,
Jim
- TulsaSpider
Re: Supercharger
Wow! I want one! Sweeeet car! How is the performance?
Re: Supercharger
Have anyone tried the Rotrex superchager?
http://www.rotrex.com/Home/Technology.aspx
Re: Supercharger
I just bought this one.
http://www.performancechiptuning.com/El ... Vortex/10/
Re: Supercharger
Is that legit? $200 for 5psi is super cheap. The fine print says you turn it on with a switch and only run it in short bursts. Not exactly a real supercharger then.ORFORD2004 wrote:I just bought this one.
I don't see a spider kit. Sounds cool though. The volumex is roots type right? How much of a benefit would a switch to twin screw make?swede wrote:Have anyone tried the Rotrex superchager?
Re: Supercharger
Yep there is no spider kit but they have used it on some Alfa models so it should work, it is however only guaranteed to work on FI enginesI don't see a spider kit. Sounds cool though. The volumex is roots type right? How much of a benefit would a switch to twin screw make?
Carbureted engines are at your own risk.
Re: Supercharger
Let us know how it works. This is just a wide open throttle on or off fan, not a variable boost system like a super charger or turbo so it won't work accross the rpm range like the others. There is a reason it is so cheap and not widely used, but if it works for you, great.
Good luck with it.
Jeff
Good luck with it.
Jeff
Re: Supercharger
Sorry, but that's going to restrict airflow, if anything.
Trey
Re: Supercharger
Will see, if it don't works, i'll but back the regular air cleaner and lost $200
Re: Supercharger
IMO things like there are scams for ricer kids, but go ahead and try it. Maybe it does work. But it looks like plastic through and through so I doubt it will hold up well. Not to mention the spider ecu not knowing what to do with it.
- Your car is a: 1975 Spider
Re: Supercharger
i have a supercharger off a mercedies , kinda looks like an ac compressor, but with bigger inlets/outlets. ive been toying with the idea, but it only makes 6psi boost. it wont be any better than a turbo spider. which ive owned 2, not much to write about, even though the first one was much faster than the second. unless i can see 12+ psi boost im not sure its for me. i want 250+hp why not.
son has 78 spider
son has 78 spider
Re: Supercharger
The performance is great!....however I can't offer a comparison to a standard Fiat spider because I've never drive one.TulsaSpider wrote:Wow! I want one! Sweeeet car! How is the performance?
What I look for when I'm after a new toy is simply something that is unique or rare. The performance is really secondary, although to be unique usually means unique performance enhancement or options.
This car is soooo much fun to step on it because of the torque and the sound! It's funny how most people buy hp and are always looking for more hp...but it's torque that makes driving fun, (and of course wind in you hair)
Cheers,
Jim
Re: Supercharger
6psi with the stock pulley. You can change them out to spin it faster.BEEK wrote:i have a supercharger off a mercedies , kinda looks like an ac compressor, but with bigger inlets/outlets. ive been toying with the idea, but it only makes 6psi boost. it wont be any better than a turbo spider. which ive owned 2, not much to write about, even though the first one was much faster than the second. unless i can see 12+ psi boost im not sure its for me. i want 250+hp why not.
Re: Supercharger
i havent a clue!, i have not researched this compressor to see if more boost is obtainable thru overdriving it or waste gate. etc.
son has 78 spider
son has 78 spider
