got a weird problem
im fixing a 2l spider block, with 2l head with brandnew 34DMS carb
im having troubles with the timing of the engine...
initial setup: crankshaftpulley points to 0 mark, campulleys (the right way put on, S and A) are pointing to the notches, the distribution is pointing to 4th cilinder, the mark on the distributor is 180 degrees other side.
after turning the engine on, it runs very bad, with the stroboscope (timingthing) I dont see the notch neather at 0 or 10 degrees, no sign of notch at the cranc at all.
so i use the stroboscope to set timing to 10 degrees by moving the distributor
engine runs still very bad, fires trough carb, no power at all...
BUT...
after putting timing to 20 - 25 degrees, degrees, engine runs fine, good power and all....
what can be wrong?
i changed the distributor, bobine, campulleys are right way
any ideas guys??
hope there are some sherlock holmses around there
regards
alfred
netherlands
