Hi everyone!
Here are some pics of my carpet replacement. At the same time, rust proofed floor using truck bed paint and aluminium insulation. figured the insulation will help with the heat without soaking up the water if the carpet gets wet!
http://www.flickr.com/photos/49366944@N ... 086513069/
Cheers
Carpet replacement
- Your car is a: 81 Spider 2000
Re: Carpet replacement
Looks like a job well done. Even got the little ones to help out! Are you doing an interior conversion to black or gray? Not sure why you went with gray carpet It looks a little out of place with the tan interior, but it does look like a nice job!
COlour is a bit off in the pictures. Carpet is beige/tan with a bit of gray. Figured it would look less dirty after a while. As to getting the youngings to help, the rule is "if they want to drive it when they're older, they have to know how to fix it"! Worked for 2 weeks!!
