Bolt size and thread for AC studs 2.0L?????
I remove my AC and now there is oil or prestone leaking from the 2 holes on the side of the engine block. I will put bolts in the holes. But what size and what lenght??????
- Your car is a: 1975 Spider
Re: Bolt size and thread for AC studs 2.0L?????
10 X 1.25MM VERY SHORT MAYBE 10MM LONG, too long and the bolts will hit the crank throw, use pst, made by loctite a pipe sealant on the bolts, so oil doesnt leak past the threads
son has 78 spider
son has 78 spider
Thanks!!!!! I will
I just found 20MM long. I'll check the clearance and cut them if necessary.
