Gears on the Fiat Spider
flopez
Post by flopez »
I have a fiat spider 1981 and the 4th gear does not work every time I try to used it makes a sound so instead I go to fifth gear I don't want to damage the transmission but besides that and the over heating the car is good Please I need some help summer is coming and I don't have a car
2ndwind
Your car is a: 1982 Spider
Re: Gears on the Fiat Spider
Post by 2ndwind »
Flopez,
1981 gear ratios:
1st 3.667:1
2nd 2.100:1
3rd 1.361:1
4th 1.000:1
5th 0.881:1
The gear ratio difference between 4th and 5th is relatively small. In fact, it is the smallest difference between any of the gears. I wish 5th gear was a little more like 0.800:1 or so. I frequently rev out third a little farther and go straight to 5th.
No harm done unless you are ...
Overheating. Three major culprits here.
#1 The fan operation: check that fan comes on at a little over 190 degrees. If not, hook it up directly to 12volts and make sure it works. If so, check/replace the sending unit at the bottom left of the radiator (had to replace mine).
#2 If you replaced the cooling fluid before this overheating started, Jack the front of the car up a mile allowing bubbles to escape, top off coolant.
#3 Thermostat may not be opening-replace and follow #2.
Steve
1982 Red Spider 2000
1919 Old Town Sailing Canoe
flopez
Post by flopez »
thank you 2ndwind for you time and experience in the manner I will follow yo instructions and will try to fix the problem but i didnt say the all story I change the water pump, the thermostat and flush the radiator thinking that is going to fix the problem but instead it become worst since i was changing all of that i decided to change the time bell thanks god the time bell problem is it fix it took me 2 weeks to figure out i dont have that much experience with cars and with the help all you and other guys Im staring to understand just little but thank you for help
flopez
Post by flopez »
adrians
Your car is a: 1981 Spider Turbo - missing the turbo
Post by adrians »
Also check that the Thermostat isn't on backwords/upside down. Do a search for the 'fitting of the Thermostat'
Regards & Welcome to the forum.
THE FLEET
2014 Abarth "SS"
flopez
Post by flopez »
Thanks adrian you were right
