Looks bad in the photos, but it can be repaired. So I will reuse it. Too costly to replace with a new one.Europa wrote:Jaime, your header bow looks rough. Does it look like you can bring it back to life?
I am going through the same process, except my frame doesn't look bad. I too cleaned, sanded, primed and painted the frame. Haven't put the new top on yet; ran out of time.
BTW, where can you get (or fabricate) the soft rubber lining at the very front of the header bow? Mine is somewhat shot and in certain areas the edge of the bow is sharp. Over time that sharp edge may cut through the new top. Any suggestions?
Not sure where to find the plastic trim, sorry...
