1) After reading the clicking sound thread about it possibly being an exhaust leak, I decided to pull off the heat shield on my exhaust just to give it a look, as I have a clicking sound that gets progressively louder and I thought it could possibly be the exhaust. I found this white buildup between the exhaust header and the downpipe. Seems to me that would indicate a leak, no? Any thoughts?
2) The opening under the engine on the exhaust manifold side seems quite large (as in there is nothing there!) and there are two bolts at the bottom of the engine with nothing on them. I realize the smog system was removed, but am I missing anything more important than that?
3) Finally, I have this foot of downward hose coming through the firewall on the exhaust side that goes nowhere. Again, is this just part of the smog system that was removed? Should I plug this line or should it be connected somewhere?
