It seems that the tower may actually be flexing a bit as I can see part of the lower portion of the tower may be a little separated from the back panel. The right side is showing some signs of this too but not near as bad.
So now that I am in this for a few hundred dollars in repairs to the carb, electrical and engine maintance I am wondering what the best option is. Replace the panels if they are available? Grind it all out and have a body shop pull it straight and just weld in some new panels and supports?
If anyone has seen or repaired this kind of problem before please post up. Im thinking the rock hard stock shocks have had a role in this happing but the rusted out towers are not helping. Funny thing is that the floors are all good as is all the rear end attachment points and cross member mounts.
Here are some pics:
Drivers side:
Passenger side:
This after i finally get the engine running good and went from this:
To now this :
