As I drove my wife's Fiat in to work today, i took a few left turns at reasonably high speed for the fun of it. The speed was enough to feel the roll of the car body. In a few of the turns, the dashboard emergency BRAKE light turned on. Could the flexing suspension geometry cause a cable to be pinched or pulled and engage the brake slightly, or is an electrical issue (bah, just a light to ignore) more likely?
I did not take any right turns at reasonably high speeds. The front driver tire has the beginnings of sidewall cracking, so I hesitate to abuse it. We'll be getting new tires within the next few days, though.
take a turn fast, 'BRAKE' light turns on
- Europa
- Your car is a: 1983 Pininfarina Spidereuropa
Re: take a turn fast, 'BRAKE' light turns on
Have you checked your brake fluid level in the reservoir?
1983 Spidereuropa
Verde Scuro
Verde Scuro
- stefhahn
Had the same last year - the lines between the reservoir and the brake master cylinder had some cracks - it could be a good idea to check them while refilling the reservoir.
ciao,
Stefan
ciao,
Stefan
That happens to me every time and the reservoir is filled up to max!??
Same deal, first thing I checked, no problems, and the light still appears. Sometimes it appears on even calm turns.Tobi wrote:That happens to me every time and the reservoir is filled up to max!??
In the turn are you contacting the e brake lever in anyway to knock it off center and set the light?
I had checked the reservoir a day or two ago, and it looked pretty well filled. Not to the brim, but plenty of fluid.
The turns weren't hard enough to shift myself into bumping the e-brake, either.
