Mysterious Piece!
azygoustoyou
Mysterious Piece!
Post by azygoustoyou »
I was able to do some more media blasting and came across this piece. Apparently it needs some parts. I remember it came off the underside in the rear. I can't remember the side though. Can these rubber pieces be purchased new. As you can see. I need them. Thanks
wachuko
Your car is a: 1981 Fiat 2000 Spider
Contact:
Re: Mysterious Piece!
Post by wachuko »
That looks like the base for the fuel filter...
Those rubber mounts are sold separately. Let me see if I can find the part number, I used one from my Porsche parts bin, so I know you can get them from Pelican Parts, just need the corresponding part number... let me see if I can find it.
azygoustoyou wrote:I was able to do some more media blasting and came across this piece. Apparently it needs some parts. I remember it came off the underside in the rear. I can't remember the side though. Can these rubber pieces be purchased new. As you can see. I need them. Thanks
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
wachuko
Contact:
Post by wachuko »
Here... again, let me check after I get home from work and I will post the correct part number:
Rubber mount
Drive Safe!
Wachuko
2015 FIAT Abarth
azygoustoyou
Thanks Jaime
launieg
Post by launieg »
If you are allowed to prowl your local auto wreckers, you'll find very similar (including the thread) rubber isolators in VW cars, and probably others. I took a pair off the firewall of a Jetta I think it was. Can't remember what it held to the firewall. Worked perfectly. Cost me 50 cents.
Launie
bajacalal
Post by bajacalal »
Anything you can fit in your pocket at the junkyard is free.
When I have attempted to pay for small, insignificant items, the mexican laides who work there seemed annoyed that I had interrupted their celebrity gossip hour and told me to just take it.
