I was able to do some more media blasting and came across this piece. Apparently it needs some parts. I remember it came off the underside in the rear. I can't remember the side though. Can these rubber pieces be purchased new. As you can see. I need them. Thanks
Mysterious Piece!
- wachuko
- Contact:
Re: Mysterious Piece!
That looks like the base for the fuel filter...
Those rubber mounts are sold separately. Let me see if I can find the part number, I used one from my Porsche parts bin, so I know you can get them from Pelican Parts, just need the corresponding part number... let me see if I can find it.
azygoustoyou wrote:I was able to do some more media blasting and came across this piece. Apparently it needs some parts. I remember it came off the underside in the rear. I can't remember the side though. Can these rubber pieces be purchased new. As you can see. I need them. Thanks
Drive Safe!
Wachuko
1967 912 Progress Thread
2012 BMW X5 xDrive35d
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- wachuko
- Contact:
Here... again, let me check after I get home from work and I will post the correct part number:
Rubber mount
Rubber mount
Drive Safe!
Wachuko
2015 FIAT Abarth
Wachuko
2015 FIAT Abarth
- launieg
If you are allowed to prowl your local auto wreckers, you'll find very similar (including the thread) rubber isolators in VW cars, and probably others. I took a pair off the firewall of a Jetta I think it was. Can't remember what it held to the firewall. Worked perfectly. Cost me 50 cents.
Launie
Anything you can fit in your pocket at the junkyard is free.
When I have attempted to pay for small, insignificant items, the mexican laides who work there seemed annoyed that I had interrupted their celebrity gossip hour and told me to just take it.
