carb on a what?!
mipstien
carb on a what?!
Post by mipstien »
have a small problem. i also couldn't find anything after searching.
i have a 1981 fiat spider. i am having trouble figuring out what carb is on the car. it SEEMS to me that the 1980's where the last cars that had carbs with a mix of carb and fuel injected in there. when i go to oreilly's here and try to find my parts for the carb rebuild they don't have any cross reference of a 1981 carb'd spider. am i goin crazy here or did someone possibly replace my engine with an older engine? and how do i figure these things out?
manoa matt
Re: carb on a what?!
Post by manoa matt »
Stuff gets swapped around by previous owners all the time, so anything is possible. "A picture is worth a thousand words" Or look on the bottom flange of the carb for identification numbers stamped in it.
mipstien
Post by mipstien »
well my problem is that even after looking i couldn't find a defined number that suggested it was a 28 or 32 numbered carb. maybe i just dont' know where to look but i have pictures in the first post i made but im not sure its close enough to even point out where the number might be.
anyways does anyone know if 1981's had carbs at all that year? according to something i found it said there where some carbs up until like 85???? is this true? if it is then i could just be unlucky lol
manoa matt
From the 1-2 pictures I could see, that carb looks like a 32/36 DFEV You also have a points distributor. The PO has changed some things around, as 81 should be fuel injected. The usual vendors should have a rebuild kit for that carb, if not try webercarbsdirect, or piercemanfolds.
mipstien
Post by mipstien »
more pictures not sure if they are even worth looking at with the breather on top. ill take it off if i have to but it does look like the 32/36 that was on the weber direct web page.
manoa matt
Its either a Weber DGEV or a DFEV. The G or F designates the rotation/orientation of the linkage. E stands for electric choke. It could also be a Holley 5200.
The carb identification numbers will be stamped into the carb base flange that mates to the intake manifold. Usually the numbers are stamped on the side facing the cam box housing making them hard to read without either an inspeciton mirror, or removing the carb.
mipstien
Post by mipstien »
thank you very much that will help me a lot. it says weber on it so i would imagine that its one of the 2 you mention. i don't know anything about carbs so ill see what i can manage ;) all i really need is the diaphram so do you know if the one for the dfev and dgev are the same ?
manoa matt
By diaphram I assume you are talking about the accelerator pump diaphram, which is near the front of the carb on the drivers side. 4 screws. All weber dual barrel downdraft carbs use the same accelerator pump diaphram, except for the IDF's. There are a few vendors that sell just the diaphram itself. Your local Napa may have it in stock as they frequently carry the redline/weber product line.
mipstien
Post by mipstien »
strange then cause i got the diaphram in a kit for a weber rebuild and it wasn't the correct one just like 1cm too big on all sides..... little odd
81s were not carbed. Look at the mfg date on the vin plate on the left door jamb.
mipstien
Post by mipstien »
so does that mean its an 80? or sold in 80 as an 81?
Snoopy
Your car is a: 1980 CS0 2000 f.i. US [Build 1979]
Post by Snoopy »
Its original an CS0 with f.i. (Carb. were CS2)
124CS008181565 is in germany :wink: in white color too f.i.
124CS008181522 is in Arizona...
CS0 2000 f.i. 79, Abarth 500C 595 2013, Ford C-MAX 1.0 Ecoboost 2015
mipstien
Post by mipstien »
Soooo the engine has a little but of stuff changed. Hmm now to figure out what is goin on with this car
