E Brake Cable
halg
E Brake Cable
Post by halg »
I am trying to find out the length(ball to ball) of a stock spider e brake cable. I am hoping that the spider cable is the same length as the rear portion of a coupe cable. The coupe cable has a second cable that goes to the handle around a pulley. IAP doesn't have a coupe cable. I hope someone has a new(not installed) cable to measure,it would be easier to measure off the car.
Hal
NebraskaSpider
Re: E Brake Cable
Post by NebraskaSpider »
What luck! I just got a new one in the mail today. Its 80 inches long from ball to ball.
Re: E Brake Cable
I believe the coupe cables are a different length
halg
Re: E Brake Cable
Post by halg »
Yep it won't work my old(bad)coupe cable is 85"long. Thanks for the quick response.
Hal
manoa matt
Re: E Brake Cable
Post by manoa matt »
Hal, you seam to be good at fabrication. Any way you can use the 80" cable and make up for it with the bracket or pulley?
Lets say we were talking about the spider e-brake mechanism and you had a short cable. You install the cable in the yoke, but can't get it stretched enough to go into the threaded adjuster rod. OK, well that adjuster rod is simply a threaded rod with a 90 deg. bend at the end and a hole drilled to accept the cotter pin. Just make a longer rod that extends further back to catch the yoke. Not a concourse piece, but how many people will be evaluating the originality of the hand brake mechanism under the car?
halg
Re: E Brake Cable
Post by halg »
Yes I can make just about anything, I just don't always have time to make everything.
Hal
spiderrey
Re: E Brake Cable
Post by spiderrey »
Have new e brake cable for coupe in san dimas , on garage wall. But I have no coupe.
