Stalling out at stop lights.
katsi
Post by katsi »
It seems that when the temp needle climbs just a tad over 190, she will no longer idle at stop lights. Under 190, no problem. Even after the previous mentioned stalling out occurs. Any thoughts? :shock: Also, nearing 190 the rolling idle seems to come back. CHOKE?
mbouse
Re: Stalling out at stop lights.
Post by mbouse »
at that temp, your choke should be wide open. is it?
katsi
Post by katsi »
Yes! It's wide open. Maybe some vaccume leak?
cooter131
Post by cooter131 »
Maybe the radiator fan kicks in at that temperature (I think 190F is arround 90C) and thus it reduces your idle rpms till it stalls.
Mine also does that and I have temporarily increased the idle speed until I find some time to check any loose or corroded ground connections.
launieg
Post by launieg »
Mind did that. But in my case, when the fan kicked it, it pulled enough juice that it robbed my coil - my spark became almost nonexistent. It wasn't that the idle rpm dropped.
I found I had a loose wire at the coil, so that the spark was just strong enough to work until the fan kicked in. When I cleaned and tightened those connections (at the coil), the problem went away.
Launie
katsi
Post by katsi »
I'll check into that but, my fan does not turn on at all. I have put in a switch to counter the problem but it does not seem to change the stallin problem. Fan on or off.
