Lets play ''Identify Craig's Clunker''
ga.spyder
Post by ga.spyder »
Here we go ...The p/o says it's a 78.I havent gotten the title yet,so who knows.The stamped cowl,vin plate,plate under hood,and door plate all match.The door says built in 11/76! SoCalMark posted that it didnt look like a 78 motor(correct..of course..He's always right).I found a little round stamped plate on intake side of block,it says: 132CBIA and under it 4194206.Here are a few pix,my question What is it ? What size motor? what carb? or basically...What the hell did I buy??? :?
Craig
I honestly have no idea about the size ,horsepower,carb,fuel pump ,or anything about this thing.I will learn,I promise!!!
Craig Nelson
Fling It Around Turns !
pope
Re: Lets play ''Identify Craig's Clunker''
Post by pope »
The cars serial # 117xxx makes it a 77. Engine looks like an 1800. Engine looks pretty clean. But you know how Fiats are. It could be a Frankenspider!
That number you gave "132CBIA and under it 4194206, is the part number for the round cover that seals off the top of the oil pump driven gear.
manoa matt
Post by manoa matt »
Yep, thats a 76 alright. The dash gauges also give it away as not being a 78.
1800cc block
1800cc head
dual plane intake manifold
32ADFA carb
Externally regulated 45 amp alternator
It should have an electonic fuel pump in the trunk by the spare tire.
The electronic ignition and rims are nice bonuses. It looks like it was well taken care of.
I'd start by replacing all the fluids, the timing belt, and all the fuel supply and return hoses before venturing too far from home. Consider replacing all the hoses and belts. It it runs good and drives ok then focus on the brakes to make sure it will stop.
kristoj
Post by kristoj »
My question is, "what's up with all that wiring in the first pic??????"
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
katsi
Post by katsi »
It looks like sombody did a re-wire job and pulled all the internal mess out and put it in the engine compartment. Probably would have been a lot easier to follow wires. But, who knows. Maybe it was assembled by "the new guy" at the fiat plant :mrgreen:
ga.spyder
Post by ga.spyder »
I think the guy who wired it is a reject from the spaghetti factory.It is a mess,but miraculously everything seems to work. The brakes work well,and the suspension has all been redone.It does have an electronic fuel pump in the trunk,and is electronic ignition.Any obvious reason to think the motor isnt the original? Where would the serial number be on that motor,so I could check it against the one on the build plate?As I checked it over in more detail today,I think I made a great deal.I have seen parts cars go for what I paid for it!
Craig Nelson
pope
Post by pope »
Craig, Look just above the motor mount bracket on the drivers side. There should be a flat spot on the block that should have the 132 number for that engine.
ga.spyder
Post by ga.spyder »
Thanks Pope,I'll check it tomorrow.Could someone post a pic of their engine compartment with the relays clipped into the plate?I need to clean that tangle up a little.
Craig
Craig Nelson
joelbert2k
Post by joelbert2k »
Check Brad Artigue's Fiat engine modification and maintenance manual http://www.artigue.com/wp-content/uploa ... 124_MM.pdf
Chapter 3 has the numbers and locations to look at.
Joel
that mess of relays is how the 75=76 models came from the factory. Originally all of the relays clipped together, but there was still a mass of wiring beneath them. From the looks of everything, you've got a late 76 model
