Finally we have a performance exhaust system to be used for stock replacement. We have a 2 1/4" system that attaches to the stock downpipe. It follows the path of the stock exhaust, down the right side of the car, good clearance over the e-brake cable, over the axle and an aftermarket muffler will mount in the same location as the stock unit. The system will eliminate the catalyst (off road use only for you law abiding drivers) and resonator. We have a Magnaflow muffler that can be added. The muff is polished stainless steel with 2 1/4 inlet and twin 3" tips.
The system is mild steel, aluminized to prevent rust. Cost is $450, the Magnaflow muffler adds $186, plus shipping of course
A high flow catalyst can be added for those that are still under going smog inspections.
A performance replacement down pipe is also available for dual outlet exhaust manifold. Cost TBA.
