Mike, I was just joking. Anyway, I did swap the lamps out and that ended up being about a 4 hour job as the screws holding the retaining ring on the pass side were stripped and rusted in place.
Anyway, sheared off the tip of my finger on the broken head lamp and managed to make both high beams not work. So, I would call it a normal attempt on my part
SO, what is that whole test light thing?
Anyway, I supposed that the head lamp ring was something that needed to be addressed anyway. I think I will invest in a test light on the way home. I have the retaining screws in my pocket and am going to try to match something up at Home Depot.
I think I will have to use more of a sheet metal screw as I had to drill out some of those little screws in the retaining ring as they sheared off on both sides when I way trying to unscrew thim with a pair of pliers.
