4 bolt conv test pipe
wengr
Post by wengr »
Does anyone offer a cat converter test pipe with 4 bolt flanges? all I find are 3 bolt flanges.
narfire
Re: 4 bolt conv test pipe
Post by narfire »
When I bought mine from Ital Motors in Edmonton, It had ANSA written on it. Perhaps a muffler place might be able to help. I found it a bit short in that I had to bend the pipe a bit as it goes over the axle so it would not rub on the panhard rod and frame. Yeup 4-bolt.
Chris
and you expected Ansa aftermarket to fit? lol Their stuff is the worst. The oem is far different than the aftermarket stuff
narfire
Post by narfire »
So Cal Mark wrote:and you expected Ansa aftermarket to fit? lol Their stuff is the worst. The oem is far different than the aftermarket stuff
Actually the header part fit great. bolted right on,good clearance with the block and steering idler. The two into one fit well , with the trans. support and the down pipes attatchment point being where they were supposed to. The cat. plug/pipe should have been 1/2 to 3/4 inch longer that was all. This was $500 cdn.,something I could not pass up. Marc's would be best,I'm sure,but the CDN $ is up and down more often than a whores drawers,giving us canuckle heads some pause in bigger purchases.
mbouse
Post by mbouse »
http://www.fiatparts.com
Bruce Matthews will be pleased to assist you
