Need a part name and function
katsi
Post by katsi »
On top of your motor their are these things/sensors that need to connect to a wire of some sort. I believe 1 is for the water temp and the other is for - I don't know. Anyway, anyone know what they are for so I can locate them on the wiring diagram? Also, what is a gulp valve \ electrovalve (located on the ignition \ water temp \ ect wiring diagram between the fan motor and the altinator)? My motor only has the sensors screwed into the top of the head and no wires hanging around even sudgesting that they might be the culprets. :shock:
Re: Need a part name and function
what year is the car?
katsi
Post by katsi »
1979
swede
Post by swede »
katsi wrote:On top of your motor their are these things/sensors that need to connect to a wire of some sort. I believe 1 is for the water temp and the other is for - I don't know.
Wires:
green/white, is the Water temp sending unit
gray/black, is the Engine ovwerheat warning switch
You can find the wiring diagram that I looked at here http://www.artigue.com/cars_wiring.html
katsi
Post by katsi »
Thanks. :D
katsi
Post by katsi »
Swede, that is so much nicer than the crappy, hard to read wiring diagram I've been going off of. Thanks again. :D
rlux4
Post by rlux4 »
Katsi; that ain't nothing, you can go to Kinkos and have them go to the websight and blow them up as large as you want. Brad has given permission for us to copy the diagrams for personal use. I had a set blown up to 11X17, I can almost hang it on the garage wall and read it from the car!
Ron
Ron Luxmore
rlux2n2@gmail.com
swede
Post by swede »
katsi wrote:Swede, that is so much nicer than the crappy, hard to read wiring diagram I've been going off of. Thanks again. :D
No problem, I love to help if I can.
