help...no head lights or left blinker??
hazards work and all other lights
68 spider no head lights
- manoa matt
Re: 68 spider no head lights
Check the fuses, then the ground connections, then the column switch.
Fuse closest to passenger side keeps blowing,how do i check column?where are grounds
Chris, see if there's a black wire coming from the headlamp assembly. That should be your ground. You may also want to check the ground at the taillamp and the ones at the rear side marker lamps too but I don't believe a ground will cause the fuse to blow. You have a shorted wire somewhere.
fuse isnt blowing anymore. is there a relay for the headlights, maybe the head light switch
Is it just your headlights or are your parking lights inop also? The headlights are fused separately so you will always have at least one working if a fuse blows. Do your high beams work? It could possibly be the headlamp switch.
problem solved, thanx for the input. black wire from headlight switch to ignition switch wiggled loose from ignition switch. now off to the blinker situation.lol. thanx chris
Hope the problem with my X19 is that simple! Glad you have it fixed.
