Varying Headlights
- launieg
Varying Headlights
I was driving home in the dark last night and noticed that sometimes the headlights go nice and bright and other times they are pretty dull. No rhyme or reason (no other varying electrical loads that I am aware of). Any suggestions ? Thanks.
Launie
- manoa matt
Re: Varying Headlights
No rhyme or reason, or vary with engine RPM's? Check your voltage regulator, the brushes might be wearing out.
Also check the big white connector at the ignition switch, all light ground connections, and the engine to body ground strap.
first, check the battery cable connections and alternator belt tension. If the basics aren't sound, no sense looking for bigger problems
- launieg
Thanks all, good advice. I'll work my way through the list and eliminate the possibilities. No rhyme or reason at all, by the way.
Launie
By 1981, I think Fiat went with the internally-regulated Bosch alternator. I would suspect the regulator if you can't correlate the fluctuations with any accessory or engine presentation. An easy-enough job to remove the alternator and have it bench-tested (usually for free). She does appear to be whispering something to you, and we all know what happens when you ignore her
I prefer to test alternators on the car. That way you have a real world situation
