Shelby Cal 500 Wheels
Anyone have any of these? I bought the below wheels with some junk tires on them the other night. They came off a 1974 Fiat and I have a 1978. The pattern seems correct but whem the lug bolts get down past the threads they are extremly tight and the lug bolt seems to shave the wheel. Anyone know what's up here?
Thanks.
Thanks.
Re: Shelby Cal 500 Wheels
Fiat uses a 4x98 wheel bolt pattern. This is an extremely difficult pattern to find.
Maybe those wheels are 4x100 which is close but will eventually fail.
They came off a 1974 Fiat though. I saw the car when I bought them... 74 and 78 patterns are the same correct?velozi wrote:Fiat uses a 4x98 wheel bolt pattern. This is an extremely difficult pattern to find.
Anyone use a adapter to go to 4 x 100? I saw them on them on http://adaptitusa.com/
- kmac33
- Your car is a: 1974 Spider
All Spiders have the 4X98 bolt pattern. There are a number of folks here on the forum that have used the adapters to go with a 4X100 wheel which is much more common.
Kevin McMullen
1980 Fiat Spider
2013 Subaru WRX
1980 Fiat Spider
2013 Subaru WRX
So no worries with the offset from the spacer?kmac33 wrote:All Spiders have the 4X98 bolt pattern. There are a number of folks here on the forum that have used the adapters to go with a 4X100 wheel which is much more common.
- Curly
I have a similar set of wheels on my AC coupe, and found that occasionally a burr develops under the wheel nut washer which makes removing the wheel bolts or sleeved nuts difficult. I've used a countersinkng drill bit to flare the wheel nut holes slightly under the flat washer which stops the burr from forming.
Curly from Oz
- kmead
I have the same wheels on my Coupe as well and they are somewhat difficult to mount up. I would clean any oxidation out of the holes and clean the bolts (the cylindrical part that contacts the hole in the wheel). A little anti seize on the bolt will do wonders as well. Be sure to torque them down properly, these rims are not hub centric so they rely only on the bolts.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
- kmead
Whoops double post
Karl
1985 Bertone X1/9
1985 Bertone X1/9
They still fit freaking tight. Like so tight I'm afraid I might break a stud off with the rattle gun. I'm going to take them to the tire shop and have them measure the pattern.kmead wrote:I have the same wheels on my Coupe as well and they are somewhat difficult to mount up. I would clean any oxidation out of the holes and clean the bolts (the cylindrical part that contacts the hole in the wheel). A little anti seize on the bolt will do wonders as well. Be sure to torque them down properly, these rims are not hub centric so they rely only on the bolts.
Is 4x100 close enough to 4x98 that you could possibly force it on? Could that be the deal here? I don't want to do this I'm just asking for my own knowledge.
- kmead
No you wouldn't be able to get them all started.PNWSmoker wrote:Is 4x100 close enough to 4x98 that you could possibly force it on? Could that be the deal here? I don't want to do this I'm just asking for my own knowledge.
Take some calipers, measure from the outside of hole to the outside of two opposing holes, write it down. Measure the distance from inside of two opposing holes, write it down. Add the two numbers together, divide by two and you will have the bolt center diameter from bolt to bolt.
With the rim off the car, how tight are the bolts into the openings in the rim?
Karl
1985 Bertone X1/9
1985 Bertone X1/9
They seem to fit fine off the car. It's just when I put them on the rattle gun has a hard time knocking them all the way down. I'll snap some close ups of the holes to show how they are chewed up a bit.kmead wrote:PNWSmoker wrote:Is 4x100 close enough to 4x98 that you could possibly force it on? Could that be the deal here? I don't want to do this I'm just asking for my own knowledge.
Maybe the lug bolts are just a bit too big?
- kmead
I would definitely measure the hole center diameter, it sounds like they are not the right size.
I presume you have run the bolts into the holes without the rims to verify they are the right thread?
I also would not use an impact wrench to run them in regardless.
Karl
1985 Bertone X1/9
1985 Bertone X1/9
Measured them last night and they are 4 x 98. I gave it another go mounting them and they do mount up but are very tight. My neighbor is a mechanic and he said they should be fine but it just seems weird that they are so tight.kmead wrote:I would definitely measure the hole center diameter, it sounds like they are not the right size.
The neighbor says "it's a Fiat what do you expect". I'll snap some pictures once I have the new tires mounted and all the wheels on.
You could use the impact wrench on your neighbor though!!
He's a Chevy guy which I am too so it's all good. He's got a bad ass Drag Nova he runs at a strip close to us.azygoustoyou wrote:You could use the impact wrench on your neighbor though!!
