Popping noise
FordPrefect
Your car is a: 1977 Fiat Spider 124
Popping noise
Post by FordPrefect »
I was driving down the highway today, in fifth, around 60 or so, and heard a loud pop from the passenger side. A few miles down the road it occurred once more, but I didn't hear it at all after, not even on the way back.
I inspected the undercarriage briefly, and all I saw was a bit of oil dripping from someplace, (which is fairly normal. :) ) but the oil was hitting the exhaust pipe.
Any helpful thoughts on unusual popping sounds from under the car?
racydave
Re: Popping noise
Post by racydave »
Same thing happened to me. Check the flex-disc on the drive shaft for missing chunks of rubber.
FordPrefect
Re: Popping noise
Yep, missing chunk of rubber.
IAP has flex joints at an ok price, but how hard are they to replace?
Also, I had a flat today, and the stupid spare doesn't work with the lug nuts I've got. Fun times.
racydave
Re: Popping noise
Post by racydave »
They are not difficult to do. Leave the band that retains it on untill its installed.If a flex-disc fails, the damage caused could be extensive! :shock:
pope
Re: Popping noise
Post by pope »
Dont drive your car until you fix the flex donut, the failure of it can be catastrophic...and I mean it.
mbouse
Re: Popping noise
Post by mbouse »
check the condition of the center support bearing while you are down there.
mdrburchette
Re: Popping noise
Post by mdrburchette »
And since you're down there, check your tranny mount. Oil leaking from the engine will eat the rubber up.
