ok, i was trying to get the diaphragm for the acc. pump detatched from the actuator on my dhsa. after very little effort (or thought, for that matter) i snapped the threaded part of it off.
so... does anyone know where i can get a replacement? i assume they don't include these in rebuild kits.
oops... broke part of my carb
Re: oops... broke part of my carb
Can you post a picture of the part you need and I'll check my carb parts.
this shows the broken rod and diaphragm. if assembled, the rod is vertical and goes from the secondary throttle actuator to the large diaphragm at the top of the carb. i think that all the dhsa's use the same part, but mine is a dhsa3 28/36 because i have a 1592cc spider.
I have a 28/36 DHSA II sitting around. I'll see if I can find the part you're looking for. Email me so it'll be easier to converse. spyderlady71@yahoo.com
