Hi- I have a 1980 Spider. I am replacing my 4-1 ehaust with a stock 4-2-1 system and replacing my ADHA dual plane carb and intake with a ADFA single plane. How much increase in HP should I expect and will there be
a significant increase in performance?
Thanks for any info.
Increased HP?
Luckilly, mine had the exhaust as stock item, I still had some springs from my small block days, they fit good. you have 2 stronger springs, these were replaced with weaker ones. I gained more initial advance, made it more responsive. Its hard to achieve base timing, and total advanced timimg with a vaccume advance, even if you use ported or part throttle vaccume ,so I disconnected it, will also remove it. before checking the timing, I drove her, wow, but it was to good at 50deg BTDC. I bought a timing light from sears with a dial, adjusted base to 10 BTDC, and total at 35 BTDC, had to slow Idle down, and re adj carb. My car idles better, and runs smoothly, with great pick up. I was fast enough to purchace on line, a 36 adl webber with manual secondaries, and a intake from a 1800 with the single plane design for the carb, which was from a 2L lancia.There are some good info regarding these mods. My carb is probally just a little rich, but all the tweaks are getting it closer, and I havnt lost my cat converter, yet..... Its nice to have something work out, me and wife enjoy drivin evening rides, and I go farther every weekend, soon to Mich? Dave
