coolant pipe deterioration
hello on my 83, both metal heater pipes on the firewall, the coolant fitting in the head where the rubber hose connects, and the hard pipe that comes off of the back of the waterpump all have some deterioration where the hoses mount. is this to be expected or is something going on?
- manoa matt
Re: coolant pipe deterioration
Yep, corrosion at those locations is expected. Starts from the inside. Just make sure the heater tube off the back of the water pump is not corroded all the way through or has thin spots.
I replaced my pipe from the water pump. but the exhaust was off at the time. Its not that hard or expensive, and good insurance for the road!
thank guys, are the waterpump pipes available new? I not seeing them in catalogs.
I believe those tubes were discontinued a couple of years ago. To stop corrosion, keep a 50/50 coolant/water mix in the cooling system and change it every two years. Otherwise electrolysis will ruin all of the aluminum in the system
I checked with Bruce ( http://www.fiatparts.com/ ) a couple of months ago and he had new stainless steel ones in stock.
Ron
Ron
aahrg, I got got a box of stuff from Bruce this week. Do you recall how much? did you get one and if so how was the fit? I need to really clean mine up and see just how bad it is.rlux4 wrote:I checked with Bruce ( http://www.fiatparts.com/ ) a couple of months ago and he had new stainless steel ones in stock.
Ron
Dang, I can't remember how much he said it was. At the time I was just checking for availability, I didn't get one. I have a spare that was given to me, but it's probably in the same shape yours is in, slightly corroded ends, and build up inside the tube.
Ron
Ron
