forgive me but......can you fit a different motor and trans
- Your car is a: 1982 FIAT SPIDER 2000
I know that there are a lot of purist out there and there should be but, I have always wondered if another type engine and transmission has ever been successfully installed in and Fiat Spider. I only think this way as I am in the throws of frustration of removing the engine and trans from my 1982 Pininfarina. This current powerplant/trans seems to be either wonderful or terrible.. I just do not know why. That has been my experience having owned three of them.
Re: forgive me but......can you fit a different motor and trans
the question is really to vague to answer. Yes, other engines can be swapped in depending on your fabrication skills. If you are hoping for a drop-in, everything bolts up situation then you really are a dreamer
- TulsaSpider
You can do anything you are able to do. I have seen a small block Ford in one. Aside from fabrication, I'd say cooling and brakes would have to be improved!
In the mid eighties there were a few guys in the SanFran Bay area that swapped with a Mazda rotary which they had turbo'd as well. They were smaller, lighter, and sat lower in th car, all of which suppposedly improved handling/performance, and they were getting good HP as well.
Anything over ±140hp would also require replacing the driveshaft and differential/axle with stronger components. If you don't live in an emissions-controlled state or province, a well-built single carb 2-litre will likely outlast you.
then if you add weight to the front end, you gotta beef up the suspension.
here is a spider with a 350 chebbi engine:
http://gallery.italiancarclub.com/michf ... 7.JPG.html
as i recall, the transmission took up quite a bit of the cockpit... don't recall if he had leg room at all, or not.
- kmead
The beast with the Chebbi is now for sale if you would like to just buy it...
http://grandrapids.craigslist.org/cto/1137082924.html
Its in Sand Lake which is not far from me.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
that car originaly sold on ebay after the build for about $11,000.00. now they want 19.
wow that's nice work.
but a little to extreme for me
howe about a fiat ritmo abarth 130 tc engine????
anyone done that
anyone done that
what exactly is a ritmo abarth 130 engine?
- Tappy
rey , its basicly the same engine as the spider but from a fiat ritmo (strada) abarth 130 tc
look here :
http://www.abarth.itgo.com/modeli/ritmo.html
look here :
i think in the us it's called a fiat strada , but here in europe its called a fiat ritmo.
I am stil thinking (dreaming) of putting a v6 in my spider
a know a guy here in holland who's selling a 3.2 v6 fom a fiat 130 coupe (165 hp)
and a 2.8 v6 (140 hp) for about 200 euro
the 3.2 should be the same as used in the lancia stratos and the fiat dino
look at picture off the engine at http://www.fiat130.nl/ under "techniek"
does anyone know where i can find the weight of these engines
and the weight of the 2 liter FI in my spider
How about a Honda S2000 engine?
http://www.youtube.com/watch?v=qeeCnMv7d6E
Trey
you can get that kind of horsepower from a modified 2 liter without the hassel of a swap and a weight penalty. but, if its just something you want to do go for it. i just read about an ol celica, 76 i think. it wasnt an easy swap on the s2000. lots of cutting and lots or wires to sort out, but it would be nice.
