Hi Guys
I plan on building a roll bar for my 124 Spider. I have access to 1 3/4 DOM tubing and a tubing bender. Can anyone tell me what the measurements are for the bars that are out there? I'm looking for height from the mounting plate to the center of the bar. I'm also needing the width from the center of the tubing on one side to the center of the tubing on the other. Also, if available, the radii of the bends. Using 1 3/4 I'll probably have to run a couple of kickers into the rear firewall. Does anyone have any pictures of similar installs? I plan on measuring and maybe bending something this weekend. If anyone has some info I would certainly appreciate it!
Thanks for all of the help!
Josh
Roll Bar Dimensions- '76 Spider
- kilrwail
Re: Roll Bar Dimensions- '76 Spider
Make sure you check the SCCA spec's for rollbars in convertibles if you plan to Solo or race your car. A yardstick across the top of the rollbar and the top of the windshield frame must be 2" above your helmet, IIRC. Your convertible top may become useless.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
- Your car is a: 1968 124 Spider
Yes, there are several roll bar rules if you plan to race. If its for looks, go for it!
I removed a roll bar to give back to the "temp" owner, Mr. Flipper. LOL anyway, I took pictures of the former install location for him. check out my photo site at http://www.flickr.com/sonosml
IA-Mike
IA-Mike
- kilrwail
Mike - Do you need to borrow a teenager? The link is good
Peter Brownhill
Peter Brownhill
you're right. i tried again, and did not get the infamous "page not found" error this time.
i have a teenager, but might consider a trade for one that would talk to me.
- kilrwail
Scott will be going to university this fall in southwestern Ontario. Stock up on groceries and I'll send him down to talk to you.
Peter Brownhill
Peter Brownhill
Thanks Mike. I appreciate the link. The bar will be for looks and a little piece of mind. I don't plan on racing the car. That gives me a good idea of how things fit together.
Josh
Josh
