Tranny and Rear end lubes
After reading all the different posts regarding tranny and rear end lubes I am scratching my head and leaking blood out of my ears. I have a 1979 Spider. What is the best available lube for the tranny and rear end? I don't want to go Europe to pick it up, I just want something that will work.
Matt
Matt
Re: Tranny and Rear end lubes
LOL, I dont know why your having a hard time, the answers are all over this forum.
Transmission- GL-1 90W non EP gear lube.
Differential- SAE 90W EP gear lube.
Good luck.
Good luck.
These do seem to be the most popular choices but in almost every forum someone offers an alternative with some explanation as to why it is better.
- Tappy
while talking about it , i'm about ordering zddp plus , can i add that to my tranny oil also , would it make a difference ?
Tappy....as long as there are no ingredients in there to make the oil slicker. I dont know if I would add it. I used a 50w motorcycle oil that was GL-1 certified that had a lot of ZDDP in there.
What does the Plus stand for on the bottle.
MSMatt... thats an advanced course that you were reading. I'm giving you the tried and true ingredients.
- Tappy
well its hard to find oils here in Belgium that contain zddp , the + stands for additive i guess (it adds zddp to your oil)pope wrote:Tappy....as long as there are no ingredients in there to make the oil slicker. I dont know if I would add it. I used a 50w motorcycle oil that was GL-1 certified that had a lot of ZDDP in there.
i've read your post somewhere on the gearboxoil you use thats wy i wondered if i could add it to a good GL1 gear oil i can find
here's the link to zddp+ : http://www.zddplus.com/
- kilrwail
Here are three oils with more than 1200 ppm Zinc, which should be available to you.
Brand Weight P ppm Zn ppm API
Castrol GTX 20w50 1157 1422 SM
Rotella 15w40 1278 1555 CI-4
Valvoline Premium Blue 15w40 1314 1838 CI-4
Better to use one of these than an additive.
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
Pete, were talking about tranny oil. The two 15W40s are a little thin for that. I think you are listing these as engine oils.
- Tappy
thx for the efford , castrol only available in 200l barrels , rotella not imported bye shell Belgium valvoline i need to check , mobile delco 1400 is available but cost 6€ l (+-28$ /gallon)kilrwail wrote:Here are three oils with more than 1200 ppm Zinc, which should be available to you.
but like pope says i was asking about tranny oil with zddp in it or , if i couldn't find it that i can use zddp plus addidtive in another GL1 graded oil
- manoa matt
Matt,
For the rear differential: Any auto parts store will have the 90W EP gear oil. Even if you can't find straight 90weight 85-90w will do. If you have leaks at the diff cover now would be a good time to take it off and replace the gasket. You can buy a 12" x12" sheet of gasket material at the parts store and trace the cover onto the sheet then cut it out. A light coating of RTV liquid gasket on each side of the gasket will ensure that it does not leak. Just make sure all surfaces are very clean before application. Brake parts cleaner works good, but don't spray it on the diff gears.
For the Tansmission: The specification is 90weight GL-1 NON EP gear oil. This is due to some brass parts in the trans. Modern EP gear oils would eat up the brass. The GL-1 oil is basically mineral oil. Its not so easy to come by, hence the big discussion when it comes to trans oil. There are several places to get it. Vick autosport has it in the Quart bottle, you will need two. IAP also has it, but at twice the price. You can find it locally at NAPA or at a tractor supply store, but it will only come in a 5 gallon bucket. and either you or your car will die before you use it all.
Filling the transmission is another story altogether.
- kilrwail
You're absolutely right. My bad. I think I saw a similar comment in another thread about motor oils, but I was probably just imagining it. Sorry for the confusion.pope wrote:Pete, were talking about tranny oil. The two 40W are a little thin for that. I think you are listing these as engine oils.
Peter Brownhill
Peter Brownhill
Yeah, what is the story on that? I am pondering a tranny oil change on my 81 Spider 2000 and I can't quite figure how it is that I am going to get oil into the thing -- particularly working in a driveway with a couple of jack stands. Is there a favored method?manoa matt wrote:Filling the transmission is another story altogether.
Tim
Hi there. Saw a thread here some time ago where you have a funnel in the engine compartment and run a line from it down the firewall to the tranny. Have a coffee can nearby as the fluid from the line has to go somewhere when the tranny is full. Sounded like a 2 person job, unless a valve of sort is on the end of the line.(I have one when racking wine)
- kilrwail
I just used a $15 push-pull plunger pump with the car on jack stands. The pump has two clear lines, with ball bearing check valves. Takes about 5-6 strokes for a litre of fluid. I made a wire clip for the end of the output line to prevent it from slipping out of the transmission. You could use a similar clip if you're going to try the gravity feed method. I also made a wooden stand with a 3.5" diameter hole in the top to prevent the one litre bottle of oil from falling over when it approaches being empty. This stuff works on all the cars, with no helper required.
Peter Brownhill
Peter Brownhill
Napa has or can get gl1 in gallons, I ordered one and had it the next day it was 10-11.00.
Trey
