shim shuffling
shim shuffling
is it ok to shuffle around valve shims in order to even out clearances? Or once the shim wears to a certain lobe it should only be replaced with new?
- Curly
Re: shim shuffling
Shuffle away
Any obviously worn shims should be thrown out.
Curly from Oz
