Hello.
I bought my -74 spider last summer. When i bought it, the 2nd gear popt out when the car "hang on the motor" Its ok when i acselrate. I had the transmisson out and opened this whinter and thought i had found the problem. The nut on the yoke whas lose and the shaft could mowe. This i thought meant that the sync.....? did not got realy attach. Everything else seamed to be ok. So anyone what can it be?? The gear whas yust the same.
PS: Sorry about my English.
Pop out of 2.nd gear
- ga.spyder
Re: Pop out of 2.nd gear
My 82 started popping out of 4th gear after I owned it for 6 months.It was a worn shift fork.It required pulling the tranny,so I went ahead with a rebuild while it was out.I was told people 'resting' their hand on the shifter can also bend the fork and cause it to pop out.
Craig
Craig
Craig Nelson
Fling It Around Turns !
mine used to pop out, found a tranny and had a guy get the sync and swap if they was good, and well it has not since
but now it sat for 17 years, i am sure it still good
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
could be too much end play, or worn slider, synchro and fork or a combination of all those
