Clutch sound
henry
Your car is a: Pininfarina 1983
Clutch sound
Post by henry »
Hello everyone,
I just change the disk clutch, it works fine, but after a week I can hear a sound when in neutral that goes off when I press the clutch. Is this normal?
Comments please,
Thank you.
Re: Clutch sound
it's normal for a transmission with worn bearings
henry
Re: Clutch sound
Post by henry »
Thank you for the replay, the transmission was completely rebuild about a year ago.
manoa matt
Re: Clutch sound
Post by manoa matt »
Is your clutch cable and pedal adjusted properly? Your throwout bearing could be in constant contact with the clutch cover plate. Adjust the cable at the throw out arm. The pedal should depress 1 inch before resistance is felt. That 1 inch of movement at the pedal equates to 2mm of movement at the throw out bearing. There should be 2mm of clearance batween the throw out bearing and the clutch plate with the pedal not depressed.
henry
Re: Clutch sound
Post by henry »
Thank you for your response.
I will check adjustments tomorrow, I applied an additive to the transmission oil, but the sound is still there.
Could it be the flywheel problem I've never refaced it.
Henry.
kristoj
Re: Clutch sound
Post by kristoj »
Wouldn't be the flywheel. I would also be very careful about putting "additives" in the tranny. The soft metal syncros are very vulnerable to the wrong type of oil. GL-1 only, or you could do serious damage over time.
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
kristoj
Re: Clutch sound
Post by kristoj »
John
'12 Abarth 500
