To remove the ball joints from the control arm:
You have to grind the three pins off around the ball joint on one side to release the ball Joint. I used an air cutting tool which worked great. I then took a punch and tapped the pin out.
To remove the bushings:
All you have to do to remove the bushing on the end of the control arms is get a pipe 1 5/8" inner diameter about 3" long. The pipe I used was 1/8" in thickness. Place it on a block or an anvil (vise) like I used. Put the control arm bushing inside the pipe and hold the control arm. Use a hammer and hit down onto the bushing. Be sure not to hit your control arm. The bushing will pop out after a couple good hits.
