Guibo failure and mystery driveway stain
Well, on my way home from work on Friday the guibo lost a large chunk as I was passing another vehicle. Fortunately, it was only about 3 miles from home so I took it easy and parked her. After the monsoons let up and I could take a good look, I also found a mystery stain in the driveway. The stain was a milky white with no other discernible color or odor. Would the guibo failure cause a transmission seal to fail and could this be the cause of the mystery stain? Also, if that is the case, how difficult is it to repair? My Dad and I have done the guibo replacement before and it isn't too bad but the thought of transmission work scares me and my wallet! Thanks!
Re: Guibo failure and mystery driveway stain
the only time I've seen a tranny problem from a guibo failure was complete destruction when the driveshaft started flailing around.
Milky substance is usually oil mixed with water. Was the stain under the tranny?
Well, as usual Mark, you are right. Once the spot got a little daylight to it and it dried for about 30 minutes the milkiness went away and only a motor oil residue was left. I have a small leak from a failed oil pan gasket, that I have been putting off for nicer weather and I guess coupled with the rain I drove through Friday and the additional rain all day yesterday that is likely where it came from. I couldn't tell precisely where it came from since I could only see it after I rolled the car forward in the driveway. I knew that it was close to the tranny but I couldn't tell just how close. Thanks for the reassurance. I know the drive shaft hasn't bounced around too much so hopefully all is good once I replace the guibo.
Leave the band on the Guibo untill it is installed, and ( oops
) take the band off before you drive it!
OK, I've read this thread over and over and I still cannot figure out what the "Guibo" is.
Can somebody help me out here?
- Your car is a: 1981 Spider Turbo - missing the turbo
The rubber donut shaped device that joining the two halfs of the drive shaft. ( has 6 bolts )
http://reviews.ebay.com/Flex-Donut-Disa ... 0002540632
THE FLEET
2014 Abarth "SS"
2014 Abarth "SS"
