1608 vs 1800
spiderrey
1608 vs 1800
Post by spiderrey »
1608 vs 1800, horsepower, torque and redline. anyone have these #,s handy?
mdrburchette
Re: 1608 vs 1800
Post by mdrburchette »
These numbers come from the factory shop manual. Evidently, it's when the 1756 was new because it doesn't have much info on it.
USA versions 1608 1756
Bore 80 mm 84 mm
Stroke 80 mm 84.050 mm
Displacement 1608 cc 1756 cc
comp ratio 8.5 to 1
max hp DIN 94 92 hp
Corresponding rpm 6,600 6200
max torque DIN 94 ft lbs 91.86 ft lbs
corresponding rpm 4,000 3000
spiderrey
Re: 1608 vs 1800
Post by spiderrey »
so if im reading this right. the 1608 has more horsepower and torque then the 1800? just higher up in the revs. and since i have a 1608 in the garage, might as well go that way. thanx denise. early spiders rule....
Re: 1608 vs 1800
bigger is better :mrgreen:
mdrburchette
Re: 1608 vs 1800
Dang, I typed that in neat columns but I guess it didn't stay that way.
Yep, that's how I read it too but I don't know when the smog pump and such enters the picture.
ventura ace
Re: 1608 vs 1800
Post by ventura ace »
mdrburchette wrote:These numbers come from the factory shop manual. Evidently, it's when the 1756 was new because it doesn't have much info on it.
USA versions---------1608-------------------1756
Bore--------------------80 mm----------------84 mm
Stroke------------------80 mm----------------84.050 mm
Displacement---------1608 cc---------------1756 cc
comp ratio-------------8.5 to 1
max hp DIN-------------94---------------------92 hp
Corresponding rpm--6,600-----------------6,200
max torque DIN-------94 ft lbs--------------91.86 ft lbs
corresponding rpm--4,000-----------------3000
Is this better? Was the compression ratio listed the same for both engines?
A
engineerted
Your car is a: 1974 124 spider
Re: 1608 vs 1800
Post by engineerted »
I would have to agree that bigger is better, the 1800 is a free revving engine just like the 1600, plus you can use any 1575, 1800, 2l cylinder heads. Any modest improvements in the engines, CR, cams, carbs, ect. will yield you bigger gains in HP and Torque over the 1600. But that being said, if you got a running 1600, use it or sell it.
Ted
Ted
mdrburchette
Re: 1608 vs 1800
That's better Alvon. No comp ratio for the 1756 in my book.
Tappy
Your car is a: 124 spider 2000 1979
Re: 1608 vs 1800
Post by Tappy »
here's the most complete list i know off :
http://www.italian-cars-club.com/Squadr ... 0-1988.xls
FineItalianAutomobile TechnologyImage
spiderrey
Re: 1608 vs 1800
Post by spiderrey »
well, if the 1800 revs as freely as the 1608, and this thing works out, ill just sell the 1608 or put it in my girlfriends sisters car. thanx guys.
