what kind of bumper is this?
- Your car is a: 1981 Spider Turbo - missing the turbo
Re: what kind of bumper is this?
Curly
Taking the car out to play with it after the bushfires ! ! ! !
Photography looks good.
THE FLEET
2014 Abarth "SS"
2014 Abarth "SS"
Curly,
What kind of bumpers did you use? That's the look I'm looking for. You have an awesome car.. Mine will look just as good. I'm trying to get it onto the Rotisserie hopefully within two weeks. Pic's will come.
- Curly
Both front and rear bars are from an 124 AC coupe. The rear one took a lot of cutting, shaping, welding and filling to match it up with the profile of the Spider rear end. Mounting brackets also had to made up and the rear valence panel strenghened where the bumper mounts on. The front bumpers only needed minor reshaping and blanking plates welded into the cut off ends. Of course they all required replating once the fit was completed.azygoustoyou wrote:Curly,
adrians wrote:Curly
Yep, doing my bit to help the local economy recover after the devestation of last month. I took SPYDUH out into the hills to have lunch at one of the small tourist towns that survived the fires but had been cut off from the rest of the world for the last few weeks.
Curly from Oz
i like the way the back bumper looks, i figured it came from a coupe. but i didnt figure you rworked it. just wondering, why dont you have a grill?
- Curly
No side-lights, no badging (apart from FIAT front & rear), but SPYDUH does have a grillspiderrey wrote:...... just wondering, why don't you have a grill?
Stainless steel woven mesh in the top and bottom grill openings, and used in the fresh air intakes at the base of the windscreen as well.
Curly from Oz
now i see it. at the angle in the other pic, it looks like its missing. looks good..
My car has these bumpers on her. It's an 80. Obviously the PO was trying to get something similar to the early chrome look but did so on the cheap. The fronts kind of look like fangs. Any idea what these are from. I haven't decided what I am going to switch them to.
David
David
the front bumper has a small dent where the over rider attaches, but you cant see it when the overrider is installed. it comes with 4 overriders.
davidwhitt,
Just unbolt your overriders (fangs) from behind. Taking them off will make your car look a lot better
Rey, Did you have them chromed recently, or did they always look this good.
this set is used, it came this way. i think good enough to bolt up and forget unless your a detail person like me. i had mine rechromed a couple years ago. i have another set after this one sells, but not as nice, not bad though.
Wow Rey...
that's a nice set of bumpers.
you only want $400.00?
yup but ill take more if offered...........
- Tappy
spiderrey wrote:yup but ill take more if offered...........
damn ....
i know sombody here in Belgium i really goin to suggest them to him this looks like a sweet deal to anyone
